Vehicle
2006 Civic Si
115k miles
6-speed manual transmission (original, including clutch)
Question
It's getting harder to shift between gears. When upshifting, I need to wait a while for revs to match perfectly in order for the shifter to fall into place, and when I'm at the track it can be tough to rev-match well enough to shift quickly. I assume the synchros are worn.
Looks like I'll need to replace the transmission before too long. What's the general recommendation for what should be replaced while I'm in there? I expect that much will just depend on visual inspection, and I'm wondering about what to look for as well. Specifically, what about:
- Clutch
- Flywheel
- Other clutch parts (slave cylinder, release bearing, release fork, etc.)
