2004 Chevy Tahoe: Car's horn went off on its own, and wouldn't stop until I pulled the fuse. This was a continuous sound of the horn. Not short honks. Vehicle was parked in my garage and the engine was off. Initially, I tried to use my key-fob's lock/unlock and panic feature, but that did nothing to stop the horn. I also started, and then turned off the engine, but that also failed to quiet the horn. When I went to put the fuse back in in the morning the horn went off again. I left the fuse out and started the vehicle and turned on the AC. I then noticed that hot air was blowing out of the passenger vents while cold air was blowing out of the drivers vent. Maybe a coincidence, maybe related. I don't know. Any ideas?
7
  • Welcome to the site. Wow, that sounds you have short in your electrical system somewhere. Asking "Any ideas?" is too broad for the format of this site, which is for asking specific questions. You have to start troubleshooting it, or take it to someone who can, to find out what is happening. Then update us with what you find. We can try to help from there.
    – CharlieRB
    Jul 10, 2017 at 20:25
  • "You have to start troubleshooting it, or take it to someone who can, to find out what is happening. Then update us with what you find." No offense, but if I did that I wouldn't be here asking for input.
    – WMMC5858
    Jul 10, 2017 at 20:32
  • Try plugging the horn in (yah, it'll be loud while you do it) and seeing if the passenger side AC decides to work, but I'll bet you these are two separate issues. Do you have the Auto A/C feature in your Tahoe (where you set the dash to a number and it cools/heats left right as you have it set), or are they manual settings? I take it they are split temps? Jul 10, 2017 at 20:46
  • The AC issue seems to have resolved itself. Now it's back to working fine. I still have the horn issue. Thanks for your input.
    – WMMC5858
    Jul 10, 2017 at 20:56
  • I read online someone else with the same issue ('01 Tahoe), found the issue to be with the horn button. They pulled up on the button itself to solve it temporarily. Jul 10, 2017 at 22:06
I would replace the horn relay. Should be in the fuse box under the hood. If you have your owners manual can you tell us which fuse you pulled?the owners manual will indicate if the fuse had anything to do with the a.c.
  • I pulled the small 15 amp fuse for the horn next to the horn relay. I put the fuse back in, and now the horn is okay (for now). The AC is still okay. It may have been due to the extreme humidity we are experiencing here in the Houston area. There were also thunderstorms and lightning in the area about the time the horn malfunctioned. Could be related ... or not. Thank you for your time and input! Much appreciated! If it happens again I'll look at the horn relay.
    – WMMC5858
    Jul 10, 2017 at 22:46
  • Addendum: I put the fuse back in after I drove the vehicle. The heat of the engine may have removed any condensation caused by the humidity (if that was the problem to begin with).
    – WMMC5858
    Jul 10, 2017 at 22:50
