Can anyone tell me what the fuel pressure should be (40lbs ?) on a 2.5 AT Sub Forester. Any hill I hit the power drops to nothing and the cruise control shuts off (which I understand, it is suppose to) Also does the fuel pump come out in a door beneath passenger side rear seat?
  • Is this just on hills? Can you go WOT on a flat road? Do you have a scan tool that can read live data or a data logging device?
    – Ben
    Jul 6 '17 at 1:24
  • pretty much just on hills. don't know about log device maybe scan tool. find out later today Jul 6 '17 at 10:19
Any engine codes being shown? Any misfire issues?
There are many reasons why a Forester can lose power - MAF sensor, crankshaft position sensors, air leaks, knock sensor, EGR valves, throttle position sensors, etc; what in particular is making you zero in on the fuel pump? I'd suggest looking at the MAF first - it's easier to get to, and if it just needs a cleaning, a $6 can of MAF cleaner is in most budgets. If it needs replacing, it's a few hundred, but junk yards will have them.
The fuel pump is accessed via an oval hole in the floor - the right rear of the luggage compartment, so just behind the passenger side rear seat. Fuel pressure should be 33-40psi, measured just after the fuel filter in the engine compartment.
    Removing the mass air flow sensor and cleaning tomorrow. Did not know this could cause the problem. Will get back to you Jul 5 '17 at 22:53
  • Just remember that you don't touch the actual sensor in the housing - just squirt it with the cleaner... if you touch it, you'll probably damage it.
    – PeteCon
    Jul 5 '17 at 23:20
  • @ForesterDave IIRC that year engine doesn't use a MAF.
    – Ben
    Jul 6 '17 at 1:22
  • @Ben is correct! I pulled up the wrong FSM. It uses a MAP sensor - which I'd recommend grabbing from a junk yard.
    – PeteCon
    Jul 6 '17 at 2:48
