I just replaced all 4 struts in my 2002 Camry. I'm about to put the tires back on, but am I good to drive off or do I need to do alignment first? I know how to check my front toe if my rear wheels are parallel already using the string method, but if nothing is aligned I'm not sure where to get started.
1 Answer
Yes, you do need to get them aligned. You'll be OK driving it to the garage to have it done.
