I would like to know how to remove the valves from the cylinder head.
  • With an appropriate tool, I guess. I'm fairly certain a quick Youtube search will provide sufficient guidance.
    – jensgram
    Jun 23 '17 at 11:16
  • Possible sometimes without a special tool - I put a spacer under the valve head and pushed down on the valve spring with a ring spanner to remove the collets - worked fine.
    Jun 23 '17 at 11:36
  • Welcome to the site. You will need to be A LOT more specific than that. Use the edit feature to add details of what you have researched, where you are at in the process of removing them and where you have gotten stuck. We will try to help from there.
    – CharlieRB
    Jun 23 '17 at 18:20
