I had a faulty indicator light on side mirror. In order to change it I had to remove the mirror. I did it, replace light with new one. But when I reassemble the mirror it looked weird. It does not look it stand right position in the case. Moreover when I adjust from electronic panel it hits the edges of the cover. Is there anything I can do about it? Like adjustment screws and so on.
2012 Skoda Octavia
photo detail edit: You can see the highlighted points that adjustable mirror hitpoints. At some point the cover blocks mirror to move further. I suspect the cover did not fit well but when I bruteforce it doesn't move either.
