Need to attach a piece of a 2x4 to a cargo van wall, but don't want to use self-drilling screws, everyone on the web recommends because I don't want to drill the walls. There's already plenty of existing factory holes in wall "beams". Is there a way to somehow put bolts in those existing holes, fix them in place, then drill a hole in the 2x4 and hold it with a nut?
Why are you resistant to self tapping screws? Afraid they will not hold? – Moab Jun 21 '17 at 23:50
Yes, not sure they will hold. But also, don't want to bother with figuring out proper length and if I get it wrong, I could puncture the outer shell. – Nikita G. Jun 22 '17 at 2:23
Length should be easy to calculate but I understand your concern. – Moab Jun 22 '17 at 23:50
There is a product "rivnut" that you can put in the hole, do up, and it locks itself into place... Like a rivet, but it has a thread and is thicker / larger.
Then you can just "bolt through" - make sure that the bolt does not push on the outer skin when it is done up though !
There are many versions, this type may be interesting for you:
Found here : https://www.rivetsonline.com/rivet-nuts-threaded-inserts-c-182.html
Interesting, I've never seen those. Wish THD and Lowe's sold them so there's no need to wait and easier to return what's left. – Nikita G. Jun 22 '17 at 2:24
