My manual transmission is stuck on neutral I was driving on freeway when I exit and took out of 6th gear it would not go into any gear no noises does it make just wount go into any gear not even reverse. Any suggestions on what I can do my self before taking to shop? I appreciate any help. Thank you
Welcome to the site. Is this a manual transmission?– Pᴀᴜʟsᴛᴇʀ2 ♦Jun 10, 2017 at 23:58
Yes it is manual– Julio erediaJun 11, 2017 at 17:06
Haha, I guess I could have just read the post ... sorry about that, lol.– Pᴀᴜʟsᴛᴇʀ2 ♦Jun 11, 2017 at 17:32
1 Answer
There are usually three possible things that I know of that prevent shifting between gears other than internal transmission problems. Hydraulic clutch master or slave cylinder issue or a bad clutch or God forbid all three at the same time.
Thank you for that. See I had the all those 3 parts replaced 3 months ago. The clutch feels normal has pressure. Jun 11, 2017 at 17:10
I remember before it gave out while going into 6th gear it felt different than all other gears. It felt as if it was forcing to go in not smooth felt as if it was rubbing against both sides gearbox? And when going out of gear same difficult to take out of gear and felt as if it would go into 5th gear at times it would and I would go to neutral from 5th Jun 11, 2017 at 17:13
