I have a Murray rear-engine riding lawn mower with a Briggs & Stratton 875 Series (190 cc) electric start engine. When cold, the mower starts up first try and runs well. After a few minutes, it begins to sputter and dies shortly afterwards. It begins smoking pretty bad as it is sputtering/dying. It does start back up after a few tries, but it immediately begins smoking and sputtering and then dies. I have tried running it without the air filter with no change.
Does the smoke smell like oil? In other words, has it been overfilled with oil? – Code4aliving Jun 6 '17 at 19:09
1Welcome to the site. Sure could use more info. How recent has this started? Was is all of a sudden or been getting worse over time? How old is the gasoline in the tank? Has the carb been cleaned recently? Have you tried a little Sea Foam in the gas? – CharlieRB Jun 6 '17 at 20:24
Several things could be the cause with your limited explanation of the symptoms. To further refine things, you should do the following:
-check the spark plug and describe what it looks like
-check the oil and describe it's looks and level
-do you smell gas after the shutdown
-how long until it starts again, and what is the engine temp when it starts?
