I got 4F0 601 025 N
wheels on my '02 Passat. They fit well, but what is bothering me is, that there is only one center cap left. Its number is 4F0 601 165
. I haven't found good deal on it anywhere, but there are a lot of cheap 8E0 601 165
's. Are they exchangeable? Thanks everyone!
Is there anyway you can link their dimensions?– Lawyer AidroosJun 3, 2017 at 21:06
1 Answer
No, these will not fit. the latter ones are 3.3 inch in diameter, and the prior ones are 2.8 inch. Besides the first ones use lug nut cusps, and the second ones do not possess those, they are just mere caps.
For 35 dollars its better you get these 4 peices: amazon.com/4pcs-AUDI-WHEEL-CENTER-BLACK/dp/B00RG4Y27U/… Jun 3, 2017 at 21:11
Thanks for the link, but those are
4F0 601 165 N
- mind the N at the end and they are sadly completely different... Both caps look very similar to this: amazon.com/Hubcap-Wheel-Center-8E0601165-pieces/dp/B0082CTSOM Jun 3, 2017 at 21:14 -
Send me the links to the caps you have found. I'll check the specs for a fit. Jun 3, 2017 at 21:23
Basically, all I found was either
SRA
version - same dimensions, slightly different colour: ebay.com/itm/… and a version without a logo: ebay.de/itm/… then I found tons of used ones, where was nothing apart from model number. Thank you! Jun 3, 2017 at 21:44 -
