I am trying to replace a fuel pressure regulator on my 2000 Honda Accord LX 3.0 engine. I bought the correct FPR. However, I am looking for the location near the engine. 1999 had it on the rail, but in 2000 it may be in a separate box by the firewall. I want to change it myself and I am searching for the location.
Looks like it's on the fuel rail by the throttle body.
2000 Honda Accord LX 3.0 Sedan
  1. Place a shop towel under the fuel pressure regulator, then relieve fuel pressure..
  2. Disconnect the vacuum hose (A) and fuel return hose (B).
Fig 1: Disconnecting Vacuum Hose & Fuel Return Hose
  1. Loosen the locking nut (C), and remove the fuel pressure regulator (D).
  2. Apply clean engine oil to a new O-ring (E), and carefully install it into its proper position.
  3. Install the fuel pressure regulator in the fuel joint. Turn it by hand until stops.
  4. Turn the fuel pressure regulator (A) counterclockwise to set the angle as shown.
Fig 2: Turning Fuel Pressure Regulator
  1. Tighten the locking nut to 29 N.m (3.0 kgf.m, 22 lbf.ft).
