I have a craftsman ride on lawnmower (42 inch deck model 25581). It recently stopped going forward. It goes in reverse when i press the pedal down (reverse) and goes in reverse faster (as if going forward) when i press the pedal forward (gas). In addition it seems the transmission does not fully disengage when i pull the wire/rod in the back that is supposed to disengage the engine/transmission so you can push it around freely. Any ideas?
1Did the pulley belt get reversed in a figure eight? – Tony Stewart Sunnyskyguy EE75 May 27 '17 at 21:25
Checkef the belts they look ok – n00b May 29 '17 at 20:34
Contact Sears. Or get a new mower. THis model has many problems – Tony Stewart Sunnyskyguy EE75 May 30 '17 at 8:01
Add a comment
