I saw this video on YouTube. It is about acetone vapor and the guy from the video it is using it to make the headlights clear and look like new. It looks very nice and I want to experiment this to my car. And this is what I did:
The first time I tried with some nail acetone; that didn’t work because that acetone is not pure and has water as ingredients.
Then I bought pure acetone from eBay. I used a modified steam cleaner with a “voltage controller” to not heat the acetone so much. I tried on some plastic protection glasses which I “sandpapered” them. Nothing happens when I spray the vapours on them. If I spray longer time, the plastic is melting and has some cracks. I don’t know what to do next to get that clear. I tried with high and low temperatures. I know that acetone is boiling at around 56 C degrees. Any suggestions on what to do? I know that I didn't present this idea so scientifically, but I am trying.
    Welcome to the site. The video you linked has no instructions. What instructions are you following?
    – CharlieRB
    Commented May 24, 2017 at 13:06
5 Answers 5
Answer: Don't.
Never heard of it. Sounds suspicious. Video you provided is unconvincing, and doesn't look like actual "oxidation". Faded headlights are physically worn, and require sanding and polishing to restore. A volatile chemical blown across the surface is not going to fix them.
Plus, acetone eats certain types of plastic. And its vapors are very flammable.
Toss aside all the acetone equipment and buy a $25 headlight restoration kit that includes sandpaper, polisher and some abrasive/polishing compound and get a drill or get some elbow grease going. enter image description here
    Does elbow grease come in regular or large ? +1 btw :)
    Commented May 25, 2017 at 18:46
There is a guy on eBay that put up a quick video showing how to clear your lights with acetone liquid as well. He says the acetone reflows the polycarbonate. In both the vapor smoothing and the straight up liquid wipe, the oxidation is always removed with various methods like sanding or machine buffing or 0000 steel wool. Once they have a smooth feel and an even white haze and you have cleaned them with distilled water and dried them off, you saturate a paper towel and lightly wipe them with a slight overlap but never wipe twice. Same concept as "Wipe New" product and some others.
Chemical intermediate
Acetone is used to synthesize methyl methacrylate. It begins with the initial conversion of acetone to acetone cyanohydrin:
(CH3)2CO + HCN → (CH3)2C(OH)CN
In a subsequent step, the nitrile is hydrolyzed to the unsaturated amide, which is esterified:
(CH3)2C(OH)CN + CH3OH → CH2=(CH3)CCO2CH3 + NH3
The third major use of acetone (about 20%)[13] is synthesizing bisphenol A. Bisphenol A is a component of many polymers such as polycarbonates, polyurethanes, and epoxy resins. The synthesis involves the condensation of acetone with phenol:
(CH3)2CO + 2 C6H5OH → (CH3)2C(C6H4OH)2 + H2O
Many millions of kilograms of acetone are consumed in the production of the solvents methyl isobutyl alcohol and methyl isobutyl ketone. These products arise via an initial aldol condensation to give diacetone alcohol.[14]
2 (CH3)2CO → (CH3)2C(OH)CH2C(O)CH3
Now with the vapor method (see 3D printing vapor smoothing as an example) there seems to be acetone (or acetone mixed with water maybe) put into a heated coffee mug with a vent cone on top. As the vapor comes out, it smooths the polycarbonate to a new look again by reflowing it at the surface. This is better than the wipe method since nothing is coming in contact with the lens as it's in a softened state. This softened state becomes hard again once the acetone liquid or vapor has dissipated.
Acetone is used in making the polycarbonate so that's why it works so well. Think of spilling hot grease on the stove and letting it cool. To reactivate it you can spill hot grease on it again and watch it turn clear and re-harden again.
https://www.youtube.com/watch?v=z2ZRKPshPVM Using acetone to reflow headlights.
The heated coffee cup with what appears to be either a hard plastic or silicone funnel to fit snugly over the cup allows acetone vapors to flow out in a small circle about two inches in diameter. https://youtu.be/iOdVqsPcqog
I was sceptical at first as I didn't know if this was a large heated cup creating a dangerous explosive vapor but apparently it's a low heat set-up. While I did not buy this product I improvised with a poly gauze pad as wetted applicator. After going thru the method of progressive sanding papers until satisfied, I wetted a fresh gauze pad with acetone wearing disposable gloves then applied in one single wipe a small area then wiping another area in the same horizontal direction, careful of over lapping. The wet acetone reacts immediately and clears the fogged lens. If applied a second time over the same area, it can cloud the lens. The gauze pad is applied and removes bits of lens material as it dries white on white on the pad. One pad per headlight lens. Since acetone dissolves polyacrylate, the wet application paints it on.
My guess is using an airbrush may be another alternative with low air pressure and zero contact with headlights similar to the heated cup method with a small diameter funnel to flow vapors onto the lens.
I’ve done this method before. It does require wet sanding the damaged surfaces. 220 grit - 2000 grit. Then using the acetone vapor to resurface the headlight. If done safely and correctly it’s magic. But yes warming acetone to the point of vaporizing is dangerous and takes a special Type of individual. Don’t try this at home. 🤔
-1
I have used Deep Woods Off, 40, spray. It has enough acetone to do the job. Spray liberally on a soft cloth, then wipe on quickly and do not go over it it again. The plastic melts rapidly. No rain or heavy moisture, like dew, for many hours, preferably about 8 hours. It takes time for the plastic to truly harden again. I assume the vapor will work better, but I do notice when I apply with cloth some dirty plastic comes off. I am familiar with vapor polishing, because we had to do some for bulb lenses at work. Not voodoo. This is an historical manufacturing process.
