My Motorcycle Suzuki sling shot, When riding the motorcycle at the traffic time when pressing the clutch it suddenly
turn off the motorcycle
But when put ON the choke and riding motorcycle
it never turn off the bike
What is the main cause of this problem.
The Motorcycle having the enough fuel for riding. But can't predict. I am very new and not knowing much information about Motorcycle controls. Guide me
Thanks
Saravanan
If when you put the choke on the engine does not quit, it indicates the engine is running too lean (not getting enough fuel).
This can be caused by a carburetor that is dirty or needs to be adjusted, an air leak between the carburetor and the engine, or bad/old fuel.
  • Hey friend thanks your suggestion. I will check it out the air leakage between the engine and carburetor and then let you know. And I used power petrol(fuel). May 17, 2017 at 5:52
  • and ofcourse i will check the adjustment/Dirty of carburetor. May 17, 2017 at 5:55
  • That is absolutely correct @CharlieRb. Thanks for your answer . Feeling good ;) May 26, 2017 at 10:17
