I want to perform a complete coolant flush on my 08 Crown Victoria. I have some 50/50 coolant and I guess the remaining distilled water will over-dilute the antifreeze. Is there a way to drain most of the water out of the cooling system? Will removing thermostat and starting the engine help with draining?
  • Do you have access to an airlift or similar tool? We use one to basically vacuum the coolant out. Also, see if your water pump has a drain plug.
    – 3Dave
    Commented May 15, 2017 at 18:54
  • there are often one or more bleeder taps that should be opened. Look at the high points of the cooling system like the top of the thermostat housing.
    – agentp
    Commented May 15, 2017 at 18:56
  • @DavidLively I only have basic tools and no wet vacuum. Worst case is I go to auto store and buy some antifreeze concentrate I guess. Commented May 15, 2017 at 19:20
  • What year is the car?
    – 3Dave
    Commented May 15, 2017 at 19:22
  • @agentp I can see something that looks like a bleeder on the engine block. Gonna check against the manual and see what it is. If I open the tap, will it help get rid of most coolant from the engine? Commented May 15, 2017 at 19:22
Don't know of a way to get all the water out. Some engines have drain plugs in the back of the block. My Ford 4.6 does, but they are rusted and hard to get to.
As an alternative, since it is nearly impossible to get all the water out, it is a good idea to use straight coolant and add 60 - 70% coolant to the system after the water flush. This will mix with the water already in the block to give you roughly a 50/50 blend.
FordTechMakuloco discusses this in his video How To Perform A Coolant Flush On Your Ford Vehicle (around 8:41 mark).
  • Thank you for the reference. I will buy coolant concentrate to mix with water in the engine block. Commented May 16, 2017 at 21:46
  • Glad to help. If this answers your question satisfactorily, feel free to give it an approving check mark so others will know the question is answered.
    – CharlieRB
    Commented May 17, 2017 at 11:31
