I am trying to replace a plastic bushing and I can't figure out how to get it in. There must be some trick to it. See photos below.
original in
new in
none in
  • Boil the part in water which should make it pliable enough to fit it into the rod end. Commented May 14, 2017 at 20:31
  • That worked, thank you. Note to posterity: you have a short time window it get it on after taking it out of the pot. Commented May 14, 2017 at 21:05
