I am trying to remove the clutch cable on an old motorcycle. This has no mid-cable adjuster/tensioner.
I've moved the nuts at the top of the lever as close to the lever as possible to make it loose, but I cannot figure out how to get the barrel out. It seems to need to come forward towards the front of the bike, then down. But, though the cable is as loose as possible, there is not enough slack to do this.
Would anyone know if there's any trick to doing this? I don't want to damage anything.
