What is the object attached to the center back of the engine compartment of a 1996 Volvo 850 as circled in red in the photo below:
Do you have a better picture? This is too grainy to get a detailed look. Also, what Volvo model is this? – CharlieRB May 8 '17 at 14:19
I see it in the engine compartment of both the 850 wagon and in the V70. Both of those had the T5 engine, I believe (which this is, right)? I don't see what it is connected to directly, but looks as though a vacuum line is attached somehow. Not sure what it is, though. – Pᴀᴜʟsᴛᴇʀ2♦ May 8 '17 at 14:43
In some of the pictures I have seen, it looks as though it has a slit loom with an electrical connector at the end. – CharlieRB May 8 '17 at 18:14
According to this video it is the horn for the alarm system. It is separate from the horns mounted by the radiator.
And eEuroparts.com shows the item as Volvo Alarm Horn - Genuine Volvo 30796932
