I have a Stihl weed whacker for which I haven't been able to find an appropriate ignition module (coil). I purchased one for a similar model that would fit and now the whacker has spark again, however I can't get it to run. There's no signs of life whatsoever.
So my question is: because this coil isn't designed for this particular model, is it possible that the timing is out due to it being a coil from a different model and it will never run with this coil (referencing that inductors shift the phase of AC systems)?
    It will be difficult for anyone to answer this question with any accuracy unless you give us model numbers, etc.
    – CharlieRB
    Commented May 1, 2017 at 11:45
The timing is (usually) set by the position of the coil on the backplate - the fixing holes have slots to allow some movement of when the spark occurs.
