I'm trying to install aluminum rivet nuts for some 8-32 hex screws. I don't have the special tool so I'm trying to do it with a nut and 2 wrenches. The problem I'm having is that the screws keep keeps sheering off at the nut (they're stainless but I don't know what their rating is). Does this mean that a #8 screw can't handle the tension needed to collapse the rivet? Is there anything else I can do (besides splurging on the proper tool)?
    There's an old saying: Right tool for the right job. If you're going to use the rivet nut, get the tool to make it work right. – Pᴀᴜʟsᴛᴇʀ2 May 1 '17 at 0:33
  • Sometimes the place you need to work in is too small for the correct tool and you need a work-around... – Solar Mike May 1 '17 at 14:29
  • It's also hard to justify the cost of an expensive tool for a small, one-time job. – WebUserLearner May 2 '17 at 0:03
  • how exactly are you doing this? You should not be torquing the screw once its threaded in place (straight pull, not turned). Why are you using a stainless screw? – agentp May 2 '17 at 14:37
Change the stainless screw for a hardened one of the same size. If that fails then you'll be splurging...
| improve this answer | |
