What I've done so far to the trans: removed pan replaced filter replaced pan gasket put it back together
Issues:
  1. I have a bad torque converter (lurches then stalls when selecting gear) no idea if i should drain the TC and refill
  2. How much Trans fluid should I add back in? I've already added 2 quarts back. the dipstick reads far over filled (because it's cold)
  • Welcome to the site. Have you ran the transmission through the gears after adding tranny fluid? – Pᴀᴜʟsᴛᴇʀ2 Apr 30 '17 at 0:41
