I have a cobalt LS 2006 model at about 100,600 miles. Around December of 2016 my cars engine start up sound became more raw. In response i had the oil and coolant changed out, but it did not revert back to its normal start up sound. So, i bough some belt dressing in the hopes that it was a 2 dollar fix. After using the dressing for a week and a half, i have deduced it is not the belt causing the noise. So, i have attached the sound file, what could this be?
https://soundcloud.com/amanda-archer-940279718
Ill add a better sound sample if needed.
    Unfortunately, it is difficult to know what you are referring to in that sound clip. It sounds normal to me. The term "raw" doesn't really give detail to what you are describing to us. What part of the "start up" sound is not normal to you? Is there a new ticking, whirling, screeching, squealing, thumping?
    – CharlieRB
    Apr 24, 2017 at 12:26
  • Normally the engine has a more muffled startup. I will say that the raw engine noise only lasts thirty seconds to a minute and it quiets down. I'll record the normal sound after the initial start up and try and find a audio clip of a normal startup sound for a cobalt.
    – NAN
    Apr 24, 2017 at 17:49
  • After googling I think I narrowed the sound down to the timing belt or it's tensioner pulley.
    – NAN
    Apr 25, 2017 at 0:14
  • Did this start suddenly, or gradually become noticeable over time?
    – 3Dave
    Apr 26, 2017 at 19:05
3 Answers 3
On newer cars, the timing chain tensioner works off of oil pressure. When your car sits, the oil pressure bleeds off. So when you start it, you hear the timing chain slapping. It a common problem especially with hondas and "entry level" chevys
Took it in. Needed a new timing belt.
be very cautious with it I owned the same car and replaced timing belt changed the oil fluids with every known tuneup and it still blew up on me after 170k miles
  • This is more of a comment than an answer.
    – Chenmunka
    Jun 27, 2017 at 8:57
