I have Wagon R (Maruti Suzuki) 2011 model with Petrol and CNG. Whenever I turn on the AC, engine stops. What could be the possible reason for this?
This is happening in both cases: Idling as well as running.
Sign up to join this communityI have Wagon R (Maruti Suzuki) 2011 model with Petrol and CNG. Whenever I turn on the AC, engine stops. What could be the possible reason for this?
Either the engine has very low power, or the load from the Air Conditioning (A/C) system is too large. Both are possibilities.
Question: With the engine OFF and the keys in your pocket, open the hood and attempt to spin the A/C compressor "center drive plate" by hand. It should spin with some effort by hand. The test requires no tools, and takes approx 30 seconds. The result of that test will tell if the A/C compressor or the engine is more likely to be the cause of the trouble. Let us know what you find.
Possibility: A/C system has too much load.
The A/C compressor could be damaged internally. This happens occasionally... compressors can be run without enough lubricant (they wear prematurely, this occurs after a leak and poor repair), compressors can be run with too much lubricant (an equally bad problem, the compressor piston will slug and break on liquid oil). Has this vehicle ever had the A/C system serviced (refrigerant removed and replaced? Leaks?) You will know immediately if the compressor is at fault when you complete the 30 second test I asked above.
If the A/C refrigerant system got plugged up somehow, that would also kill the engine, and you might not see that with the 30 second test. In that condition, the engine would die about 20 seconds or so after you turn the A/C on...
If you have an poor cooling system (e.g. the cooling fan is inoperative, or the radiator / condenser airflow is blocked) this too would place too much load on the engine, although I wouldn't expect this to occur immediately when you turn on the A/C, rather it would take five or ten minutes in hot weather.
Possibility: The engine is not putting out the correct power. I don't recognize the vehicle type. I'm assuming this is a modern engine with computer controlled fuel injection. If so, the computer should give you feedback on potential power issues (at least relating to the fuel system.) Note: the computer control system is not so great on giving feedback on spark or air related power issues. If there is a bad spark plug, you may not receive feedback.. I will say if that were the case, the vehicle would idle poorly even with the A/C off.
Question: Is this vehicle fuel injected (or perhaps old skool carbureted?)
In fact, it's quite possible that the engine is totally good, and the A/C system is also totally good. Because the A/C load is so high, modern computer controlled cars delay the A/C clutch engagement until the engine gets a rpm bump up. This happens so quickly you wouldn't notice. If the "idle bump up" system is not working correctly this would be bad. On old skool carburetor vehicles they had a solenoid actuator that would accomplish this by moving the butterfly valve a bit.. Does your vehicle idle speed control system function correctly? You haven't changed the wiring that drives the A/C clutch have you?
Let us know the results of your "spin the A/C compressor" test...
