Where are the coilpacks located in a 1998 Buick LeSabre? Images would be most appreciated.
Robert
Sign up to join this communityWhere are the coilpacks located in a 1998 Buick LeSabre? Images would be most appreciated.
Robert
Looks like the front U.S. driver's side, unless the engine is transverse-mounted. Google got me these:
The above picture is of a 2004 model, but placement will probably be the same across most model years. Another post found via Google seems to confirm this, if you presume "left side" to mean the left side of the vehicle and not the person working on it:
http://wiki.answers.com/Q/How_do_to_change_a_Ignition_coil_on_a_98%27_buick_lesabre
To locate ignition coil (IC): open hood, to left side of engine there are 3 IC's bolted to cylinder head; they have spark plug wires attached to them (6 wires between all 3 IC's).
Pics are from an article on UnderHoodService.com.
http://www.underhoodservice.com/Article/40247/servicing_gms_3800_v6_engines.aspx
