My Subaru Forester 2014, has its driver side power window stuck while closed. It was up all winter and now its not responding.
Does OBD tell if the motor had gone bad, or something else ?
Sign up to join this communityMy Subaru Forester 2014, has its driver side power window stuck while closed. It was up all winter and now its not responding.
Do you have a test probe? If so, check that the buttons are sending a current to the motor's relays. If you've left it in one position, it might be a good idea to use a silicon spray into all the grooves. If this doesn't work, pull out the door cards and directly supply the motor with 12DCV from either the battery or a test probe (preferably.)
If it's stuck after testing that, you may need a new motor. Good luck!
