I have a nitro remote-controlled nb16 buggy.
When I put the glowstarter in the engine and start the engine and remove the glowstarter everything runs fine.
However, once I press the accelerator on the remote controller the buggy gives a little rev and the engine quits.
How do you fix this ?
    Open the main needle a bit. Sounds like it's not getting enough gas.
    – cory
    Apr 13, 2017 at 15:45
    Will the engine on the buggy continue to idle if you don't touch the throttle? Or does it quit after some time? Apr 13, 2017 at 16:41
  • It continues to idle but then it quits when I press the accelerator on the remote
    – Dan Khan
    Apr 13, 2017 at 17:00
  • It's okay I fixed it. The engine was too rich and so was getting to much gas so I had to lean out the high speed needle :)
    – Dan Khan
    Apr 14, 2017 at 18:13
