I have a 2005 f150 fx4 and I just lost reverse, I'm curious as to how many book hours a shop will charge to replace transmission. thanks for reading
1Whoever posted this as POB, you need to retract your vote. This is a straightforward question which can be answered objectively. Book hour questions are on-topic for this stack. To the OP ... Welcome to the site. Someone should be able to get you an answer to your question.– Pᴀᴜʟsᴛᴇʀ2 ♦Apr 9, 2017 at 11:56
Do you have an automatic or standard shift transmission?– Pᴀᴜʟsᴛᴇʀ2 ♦Apr 9, 2017 at 11:59
1 Answer
Remove & Replace on an 4x4 Automatic is 6.6hrs. This doesn't include fluid fill or any other maintenance work like the filter so add another .5 hrs or so.
Sweet, thank you very much for the quick response...😊 btw it's an automatic– dankerApr 12, 2017 at 3:59
