I just installed new hydraulic tappet set due to noisy old hydraulic tappets. 90% noise(tik-tik) is gone. 30-40 kilometres are done after new hydraulics installation but still 10% tik tik noise can be heard. So how to make engine less noisy after getting hot ? Push rod, cam gear, cam sleevee, Hydraulic tappet whole set changed recently.
  • Are you using the correct grade / specification of oil? Has the oil and filter been changed recently? Is the oil reaching the tappets in sufficient volume? is one of the galleries (partially) blocked?
    Mar 31, 2017 at 15:07
  • @SolarMike i am using royal enfield liquid gun 15w-50 and changed about 1k kms Mar 31, 2017 at 15:08
  • So, what do the manufacturers specify as oil for that engine?
    Mar 31, 2017 at 15:09
  • @SolarMike its a default oil provided by royal enfield company service stations. Mar 31, 2017 at 15:11
Tappet noise is a "feature" provided by RE on Classic 350. While it doesn't do any harm as such, you can get the tappet rods set changed (the ones on Himalayan seem to be better : these are lengthier and have a groove). Tappet noise doesn't get better with the mileage. It gets better only with tappet rod adjustments AFAIK.
