The van cranks but will not start now. Checked for spark and fuel, all is good.
Below is the scan results I got. This scan was taken after several tries and checking the cam and crank sensors.
Make: Kia
Model: Sedona 3.8L
Year: 2006
VIN: KNDMB233366060650
MIL: Off
Diagnostic Trouble Codes
Generic Powertrain
P2106 Lime Home Mode - Force Limited Power
P1295 Limp Home Mode - Power Management
P2422 Evaporative Emission System Vent Valve Stuck Close
P0300 Random/Multiple Cylinder Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P161b Unknown Trouble Code Description
P0018 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor A
Freeze Frame for DTC P0300
Fuel System Status Bank One Closed Loop
Fuel System Status Bank Two Not Reported
Calculated Load 27 %
Coolant Temperature 93 F
Short Term Fuel Trim Bank One 17.94 %
Long Term Fuel Trim Bank One 0.00 %
Short Term Fuel Trim Bank Two 18.72 %
Long Term Fuel Trim Bank Two 0.00 %
Intake Manifold Absolute Pressure 20.9 in.hg
Engine RPM 2340 r/min
Vehicle Speed 0 MPH
Ignition Timing Advance for #1 19.0 deg
Intake Air Temperature 82 F
Air Flow Rate From Mass Air Flow Sensor 3.15 lb/min
Absolute Throttle Position 22 %
B1S1 O2 Sensor Output Voltage 0.000 V
B1S2 O2 Sensor Output Voltage 1.275 V
B2S1 O2 Sensor Output Voltage 0.000 V
B2S2 O2 Sensor Output Voltage 1.275 V
Enhanced Powertrain
B3b12 Unknown Trouble Code Description
U20bb Unknown Trouble Code Description
P22e0 Unknown Trouble Code Description
B3f04 Unknown Trouble Code Description
B2099 Unknown Trouble Code Description
Automatic Transmission
SRS-Airbag
B2500 Warning Lamp Fault Short To Battery Or Bulb Short
Weight Control System (WCS)
No response from module
ABS / TCS / ESP
BCM
B1102 Battery Voltage Too Low
B1602 CAN Line Error
B1606 CAN Time-Out ADM
Air Conditioning
Powertail Gate
Power Sliding Door LH
Power Sliding Door RH
TPMS
No diagnostic codes retrieved
