Here's what I have done so far:
Replaced the battery (it was dead) Replaced the battery cables (they were super old) Replaced the starter relay
For a while, the car would start intermittently. If I waited a couple of days, it would start up no problem. Now, it won't start at all.
2002 Ford Taurus SES.
Thanks for your help!
  • Is the battery dead again?
    – CharlieRB
    Mar 30, 2017 at 12:32
Put a multimeter on the leads running to the starter solenoid, and see if it's getting power when you have the key turned to "start". If it does, you need a new starter. If it doesn't, you have an problem between the ignition and the starter. BTW - the "previously intermittent start problem" is a classic "starter solenoid going bad" symptom.
