I have a 1995 Buick Regal Custom. When I start the car, it spins but doesn't turn over. Electronics work fine and I got the battery tested and both the battery and alternator are completely fine.
When I turn the key back, I notice a buzzing electronic sound coming from the back of the car. It's a lot like a spinning sound and it is not coming from the engine.
This usually only happens if we don't plug the car in on a cold day. But it's not cold at all and even after being plugged in, it still won't start. ​​​​​​​It's probably not the starter since I hear a buzzing sound coming from around the back wheel area instead of ticking sound in the front.
I have expended my only knowledge about cars from my time in automotive class. What do you think it could be?
    Is the humming when the key is in the "accessory" position or "off" position? Mar 23, 2017 at 20:52
  • Off. Even when the key is out the sound is there. Lasts about 3 to 5 mins
    – Jess
    Mar 24, 2017 at 2:04
  • I wonder if you're hearing the fuel pump? May be worth removing each fuse in turn and when you find the one which stops the sound, that'll narrow down what the noise is. My gut says fuel pump relay but I'm not at all sure. Mar 24, 2017 at 11:48
3 Answers 3
Ok, so to draw a little bit of a picture with words, the start cycle is basically:
  1. Pump fuel
  2. Rotate motor
  3. Intake fuel/air mixture
  4. Ignite
Note that the above is not necessarily in that order and there are some nuances left out.
However, of the components involved in the ignition cycle, most are in the engine bay (engine, starter, ignition system etc). The only component involved in engine starting at all that is located near the rear, is the fuel pump. So this could be the culprit, however it is most likely not the source of the whirring/humming noise. The fuel pump will only operate when the ignition is in the "on" and in some cases "acc" positions, but almost never in the "off" and certainly not the key out position.
There are a couple other possibilities that could create a sound like that which have nothing to do with you engine issue. The 2 that come to mind are power antenna being stuck (odd that the sound would last so long but I have seen this several times in vehicles as the culprit of a phantom whirring noise) or possibly air suspension if the package is installed.
Now if we consider only the engine not starting, there are a few possibilities.
  1. Not getting air/fuel for combustion a. Valves could be a factor
  2. Not getting spark for ignition
  3. Starter not actually turning motor
You said the starter and power checks out, so we can theoretically eliminate #3.
It is possible that it's not getting air/fuel, but that would usually have other attributes as well.
If it's not getting sufficient spark (little or none or wrong timing) it may also not start (or worse).
What it comes down to in my personal experience debugging no-start scenarios is what does the motor sound like. Is it a dry raspy spinning sound or a wet chugging?
The sound by the engine is the starter spinning. Because you have had the battery tested, I am guessing the starter solenoid (part of the starter) is defective and the starter needs to be replaced.
If the solenoid isn't working, the starter will spin but not engage the engine.
  • There is no noise at the front of the car. I try to start the car and it spins. I stop trying to start it and a buzzing sound happens from the back. The back doesn't nornally sound like that after turning off the car and only appears when my care refuses to start. Like I said, there is no unusual noises at the front. None whatsoever.
    – Jess
    Mar 23, 2017 at 20:37
  • I reworded my answer to be more clear and removed the part about the fuel pump now that you have added more details in your comments of the question.
    – CharlieRB
    Mar 24, 2017 at 11:27
  • You stated "When I start the car, it spins but doesn't turn over." so the answer by @CharlieRB is relevant. The sound from the back of the car is probably the fuel pump - check to see if the pump is fitted at the back on your model.
    Mar 24, 2017 at 11:30
If your car is turning over, and your battery checks out, then I would guess that your battery, starter and solenoid should all be fine. Because there is a humming sound coming from the back, I would also look at the fuel pump. An engine needs two basic things to run, fuel and spark. If you take away either one, it won't run. I would also guess that its not a fuse because if the fuel pump is making noise then it has power. Its an older car so the fuel filter could be clogged as well.
One more thing, if your car has auto leveling suspension, it might also make a noise but if it is trying to level a car that has sat still, you have other problems.
