I do a load of night driving during my commute, clocking 4 hours a day during the winter. I have been using the Sliverstar Ultra bulbs, but due to my night drives, I am blowing though a pair every 6 months or so. I recently found out by actually checking the packaging that the lifespan of the bulbs is 150 hours, and at $50 a set, is both expensive and ecologically dubious.
I have seen threads and done some research on LED replacement bulbs that will be a simple swap in the same headlight housing. However, I am not clear on what can actually be used. Some have SAE and/or DOT certification. However, I have also read that these are super conservative guidelines. Some are said not to fit in the housing without intervention. The most Highly rated/recommended LED headlight replacements I have seen come with an "Offroad use only" disclaimer.
What is actually required to use drop in non HID-LED lights without getting a ticket/being a hazard to other drivers? Does anyone have any brand/model recommendations?
