I'm really struggling to identify the model number for my radio/sat nav unit so I can find a manual online.
Can anyone help me with a model number for this unit?
sat nav appearance
Edit:
I found the manual eventually by googling s-max blaupunkt travelpilot manual. Download the manual from here.
I believe the information is as follows, but whether it helps you find a manual is beyond me:
Make:         Ford
Model:        TravelPilot EX
Part/Model:   7 612 300 516 (7M5T-18K931-AE) NOTE: The part in parens may be different
Manufacturer: Blaupunkt
The reason I say the one part may be different is, I found this video which specifies for another radio which is setup exactly as yours, but the facing is different colors. Hope this helps you find what you're looking for.
|improve this answer|||||
    Great. I had no inkling it could be blaupunkt. This is definitely useful information, thanks. – Paul Suart Mar 9 '17 at 22:15
  • Found the manual with the keyword blaupunkt in my search. Cheers! – Paul Suart Mar 10 '17 at 16:36
I think, if you go on the Ford website (https://www.etis.ford.com/vehicleSelection.do) then you may find by entering the VIN you should get some details about your car - whether it is sufficient not sure but may help.
  • I tried that (sorry, should have said in question). The closest I get is a document like this: fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/… which gives information about two radio units... neither of which is like mine. I have the same issue with the paper manuals in the car - none of them contain info about my unit. – Paul Suart Mar 10 '17 at 8:44
  • So, have you tried a dealer? Apologies if you have... – Solar Mike Mar 10 '17 at 8:47
  • That's the final option. I'm time-poor so don't really want to make a special trip for this. – Paul Suart Mar 10 '17 at 8:48
