I did something really silly last night :( - I have a 03 Accord V6 sedan that I recently changed the transmission. After I hooked up the new tranny etc.. I noticed when I start the car the SRS, (!) and the ABS lights came on.
I decided to research it and was following a tutorial online where a lot of people tried and it worked: It basically instructs you to bridge pin 4 and 9 on the ODB2 connector, I did just that and saw a little spark - I immediately removed the bridge and tried to start the car to no avail, it cranks well - just wont start up. I hope this is just a blown fuse/relay somewhere. Any help on fuze/relay location to check etc would be highly appreciated.
**Side note to that, now when I put the key in the Ignition the Green key light keeps blinking as if the immobilizer isnt recognizing the key.
Could I coincidentally have a bad key ? fuse? :(
Thanks for the help in advance.
