Had a pretty bad coolant leak recently, and I was pretty sure it was the Water Pump, so I replaced the following:
- GMB Water Pump + gasket + RTV
- Hayden Fan Clutch
- Stant Thermostat + gasket
- Lower hose and clamps
- Teflon on the threads
After two weeks of bone dry operation I was sure that the issue was fixed, but today I discovered the leak again. Same locations as before, just a much slower leak. It seems to be mainly in the front of the engine, but also travels to the back. (See pictures below). Is it possible the water pump failed again? Are there other things I should check for? Any help is appreciated.
