I am repairing the coilover of a Yamaha XT600 2kf and I need to replace a radial shaft seal. Unfortunately I have not been able to identify the exact type of seal this is. I have only been able to find the standard ones like this:
These are some images of the one I have:
https://i.sstatic.net/ey4Z7.jpg
As you can see a standard radial shaft seal will not fit. I would like to know what this type of seal is called and where I can find them. Thanks in advance.
Update: enter image description here enter image description here These measurements correspond to the markings on the seal. The markings are :BJ-14 25 7-25. Searching for the markings on google did not lead to any useful results.
  • Going on your image, I would suggest that what you are calling a seal is actually a dust cover, perhaps there is a different seal underneath.
    Commented Mar 2, 2017 at 13:42
  • I have added some information to the original question. I am certain that this is indeed a seal. The material and the markings are typical of radial shaft seals, this is just a special form or type. Commented Mar 2, 2017 at 14:22
  • Then I would take it to a specialist bearing / seal supplier who could help.
    Commented Mar 2, 2017 at 16:17
There is this site that may help: grainger.com/mobile/category/rotary-shaft-seals/bearings/power-transmission/ecatalog/N-kz2Z1z0nx5v
Take the seal to an industrial bearing, seal distributor. I have been a Machine repair technician for a company, it always is good to have hands on. Grainger is a good start for parts if there is one in your area. Make sure to search for local outlets.
New contributor
Darrell Thurston is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
