I just replaced heater core on my 99 f150 and now no controls are working. I think it's a vacuum problem but not sure where to look. Dash is not completely back together but enough to check it out. I hope i don't have to drop dash again. Thanks
1Welcome to the site! I'm sorry to say but I do not fully understand what your question is. Do you mind making an edit to clarify?– HᴇʀʙɪᴇFeb 28, 2017 at 15:50
1When you say controls, which ones do you mean? The amount of heat? The selector for directing the heat to defrost, floor, panel, etc?– CharlieRBFeb 28, 2017 at 16:19
1 Answer
I would first check you are getting vacuum and then make sure the pipes are in the correct places.
