My low and high beam headlight don't turn on. I already checked the bulb and relay. The headlight switch handle is strong and when I pulled to me it doesn't return to his original place alone.
  • Welcome to the site. How did you check the bulb and relay if the headlights won't turn on? Am I not understanding what you are saying? Is it only one headlight you are having issue with or both? – CharlieRB Feb 27 '17 at 21:08
  • Thanks! Sorry if I don't explain well, my principal language is spanish. Both headlight don't turn on. I checked both bulbs with the battery directly and both are good. The relays are already checked too. – P.marie Feb 28 '17 at 1:32
  • With that information and what you described about the switch handle, it sounds like the switch has gone bad. – CharlieRB Feb 28 '17 at 12:24
