I just purchased a valve spring compressor that has a lever on both ends, similar to this one:
Two-lever valve spring compressor
What is not clear to me is the advantage of having this two-lever setup.
What does it have over the more common single-lever design like this one?
Single-lever valve spring compressor
  • @CharlieRB yes, especially if you push the cap down and it goes deep into the housing... – Solar Mike Feb 27 '17 at 13:14
Doesn't appear to have a special purpose other than convenience. According to the Draper Tools Website;
Suitable for use on most engines due to double-ended valve cup. Unique double action lever cams action provide choice of operation either above or below valve.
