The reason why I ask is because tires can gain pressure (psi) when being driven (heat gained from friction which increases internal tire pressure) so I'm not sure what that number exactly entails. Does the manufacturers suggested inflation pressure mean the pressure in the tire should match that value at all times? Tires gain psi when being driven so how is it possible to always be at that exact psi value unless I'm constantly changing the psi in the tires. I'm guessing the number set by the manufacturer is in reference of the minimum value that a cold tire air pressure should be set to. This would mean that slight over inflation is better than under inflation from a practical standpoint. Am I wrong?
  • cold inflation pressure is exactly what it says. The pressure will go up a bit when hot and that is normal and expected. If you adjust your pressure to the cold number while they are hot you will be underinflated.
    – agentp
    Feb 19, 2017 at 15:31
  • My question is asking whether or not that manufacturer's cold tire inflation pressure is a constant value, a minimum value or a maximum value. I already understand that the pressure varies according to temperature.
    – Narcotixs
    Feb 22, 2017 at 23:40
It is actually far more complicated than that.
The manufacturer suggested tire pressure is for the tires, cold, before driving. The problem with this is the suggested value is for the specific tires that the car came with. It is possible to replace the tires with ones that would be over inflated or under inflated by the suggested value.
Cars normally come with 44psi max tires. There are 35psi max tires. Inflating them to the suggested sticker would be over inflating them.
Many trucks come with 44psi max tires. There are 55psi max tires (load range E). Inflating them to the suggested sticker would be under inflating them.
Follow the recommendation for the tire not the car.
    If your sidewall max pressure is less than the car manufacturers recommendation you are running incorrect tires. If you are running some specialty tires (significantly oversize off road truck tires for example) that may be the case, but for a usual passenger car situation you should follow the vehicle mfg recommendation.
    – agentp
    Feb 19, 2017 at 15:23
  • I'm not sure if this is correct. I think it's general knowledge to inflate towards the vehicle manufacturer recommendation and not the tire sidewall because a tire can be used on any vehicle.
    – Narcotixs
Then the manufacturer sets the cold-inflation pressure they're aiming for a desired pressure at running temperature. They adjust that down to a cold-inflation pressure by assuming a given amount of temperature increase from cold.
Manufacturers tend to set the recommended pressure toward the low end of the desirable range to give a softer ride. (At least, for typical passenger cars.) So, yes, slight over inflation is definitely more desirable than slight under inflation.
