This is in a motorcycle. I'm having issues in the charging system.
I tried to rule out some things by connecting the output of the regulator directly to the battery, but the voltage is lower than when connected regularly. Why would that be?
Also why is the R/R output less than 1 volt if the output cable is unplugged? (probably related questions).
