I bought a brand new Royal Enfield Classic 350 and I rode around 1200 km. Since the delivery of bike, I have faced a recurring problem with the engine shutting down while the bike is running.
When I drive the bike for around 50 km at a speed of 60-80kph, the problem occurs. After two or three minutes, the engine can start normally and later the problem repeats. While the bike is shutting off, the engine acts like it's going out of fuel. I checked with the company service center, the fuel valve got cleaned, the fuel line got cleaned, but still the problem persists. Can anyone give some suggestion for this?
3 Answers 3
There was a minor dust particle which lies inside carburator, after cleaning it got resolved
  • Crazy how those carbs can mess up anything :). Glad you got it fixed.
    – Cullub
    Oct 5, 2018 at 23:05
  • But carbs are the best thing @Cullub Oct 8, 2018 at 4:56
I have this recurring problem as well..it’s due to the poor design of the bs4 tank and it causes air lock inside the tank ..open the tank and close it and then start the engine in fuel ON mode ..hope this helps :)
-2
I faced the same problem in Gixxer, the problem was solved after the fuel injector plunger was changed. Generally the mechanics understand when you say to change the pin in the fuel injector.
    Weird. I was mechanic for awhile and have never heard of a fuel injector pin. Do you have a picture? Can you explain it? Do you have a diagram you can share ? Feb 22, 2017 at 4:01
  • The OP probably means "pintle," the mechanical part of the injector that moves and permits or prohibits fuel from passing through into the combustion chamber or intake manifold. Oct 6, 2018 at 0:27
