On a Hyundai Accent CRDI 3 cylinders, there is no signal on the injectors wires during cranking but if the car is forced to start with other methods the injectors will start getting the signal and operates normally ( so their wiring is good ), the car shows no codes on the scanner, it had camshaft problem but it is gone now. All injectors wires are connected directly to the ecu
what could be the reason ?
  • does the car use a cold start injector?
    – Ben
    Commented Feb 13, 2017 at 23:57
  • @Ben don't know what that is
    – Chebhou
    Commented Feb 14, 2017 at 14:35
