What I mean by that, is instead of using the fuel cell to produce electricity, is there a product where the fuel cell is used to split water and half the gas is used for the ICE and the other goes back into the fuel cell to power it? Is there a product like that I can buy?
So, you could investigate how much energy is needed to separate Hydrogen and oxygen? will the amount produced be sufficient to power the ICE AND the fuel cell? – Solar Mike Feb 7 '17 at 10:19
I want to know will it be enough to power and ICE while also generating enough power to power it self. – DeusIIXII Feb 7 '17 at 10:33
I read your question with the idea you are looking for perpetual motion - so again : research the energy it takes to break the bonds between hydrogen and oxygen etc – Solar Mike Feb 7 '17 at 10:46
Well i wont say its perpetual motion as you would stil need energy to split the water. But thanks for the guidance – DeusIIXII Feb 7 '17 at 11:25
"still need energy to split the water " exactly the point I was making in my original answer... – Solar Mike Feb 7 '17 at 14:11
Actually, a fuel cell won't produce hydrogen. Electrolysis will.
So, what you are suggesting is using hydrogen to power a fuel cell and the obtained electricity for electrolysis to obtain hydrogen.
Now, the problem is that if you divert half of the obtained hydrogen to an internal combustion engine, only half of the energy remains in the rest. So, every cycle of this machine will mean you have less and less hydrogen.
The system will work only if you have a big hydrogen tank somewhere. The tank will eventually be depleted. Now, if you have a big hydrogen tank, why don't you directly power an internal combustion engine by using the hydrogen, or better yet, power the fuel cell and use all of the electricity in electric motors, without trying to waste the electricity in electrolysis?
No. The energy you get from burning hydrogen cannot possibly be more than the energy you spend splitting it. Perpetual motion machines are physically impossible.
Also, when you burn fuel in an ICE, it will at best recover about 35% of that energy as motion, driving the wheels and/or a generator. The remainder is lost (to friction, exhaust gas velocity etc.)
There have been a few hydrogen ICEs (BMW had a few 7-series converted as test vehicles), they all used high-pressure gas bottles or a metal hydride tank as storage.
