This is a KIA Rio 2015 with an automatic transmission . when the lever is on the D position it shifts to the 3d gear directly ( doesn't move until I let the brakes ). using the scanner it showed two codes :
- P0755 Shift Solenoid "B" ( Active )
- P0743 Torque converter Clutch circuit electrical (Active )
the problem appeared after an transmission oil change. so i changed it again in case it was a bad one and cleared the codes. if i change gears ( move the lever ) while the ignition ON and engine OFF then start the car I can drive normally (can change to any gear 1,2,3,4 ) and the problem won't come up. but if I start the engine directly puting the lever on D will make the car shift to 3d gear
what should I check ?
I think the transmission name is A4CF2
