On the car the dim/bright works on the driver side, but on the passenger side the dim doesn't work but the bright does. I have tried 2 new lights with no avail.
Have you checked for burnt fuses? Frequently the fuses are split left and right so that you don't lose all light if the fuse blows. – procrastilater Jan 23 '17 at 14:41
The dim/bright works on the driver side but only the bright works on the passenger side – Cody Jan 23 '17 at 23:29
Is this still a problem you are trying to resolve? If not, can you tell us what fixed it? – CharlieRB Feb 23 '17 at 18:09
Check for a burnt fuse
It is quite possible that the fuse is blown. Frequently, the fuses are split side to side so that if the fuse for the left light blows or you get a short in the left light circuit, you won't lose all your light while you're driving.
My recommendation is that you check for blown fuses. Look at your electrical diagram and see which fuse goes with the right side. If replacing the fuse doesn't help, check for circuit continuity and resistance.
Edit:
After further research, it appears that the issue probably lies under fuse 15 in this diagram:
(Courtesy of autogenius.info)
It's a 10 amp fuse, and I suspect it's blown. Replace it.
