When I was driving to work today in my Mazda B3000 truck when I went through a rather deep puddle of water. Immediately my battery indicator went on and it was very difficult to steer, as if my power steering went out. A little later I saw a "check gauge go on" for about 30 seconds and then went back off. Any ideas what could have caused this?
How is it running now?– Pᴀᴜʟsᴛᴇʀ2 ♦Jan 20, 2017 at 16:12
I parked it at my work and its been sitting there so I may try to start it up around lunch and report back.– James BilousJan 20, 2017 at 16:20
Is the power steering electric or hydraulic?– HobbesJan 20, 2017 at 16:32
@Hobbes - It should be hydraulic.– Pᴀᴜʟsᴛᴇʀ2 ♦Jan 20, 2017 at 17:04
What's with Mazdas and puddles in the past couple days? Both of these made HNQ.– jpmc26Jan 20, 2017 at 22:30
1 Answer
My first thought is that the belt(s) that drive the accessories (alternator and power steering) slipped due to being wet. As for the check gauges light that came on later, I don't know. When it came on, did you catch which gauges where high or low?
Unfortunately I did not, it was very brief. I'm thinking it's the belt as well since everything else seems to work alright. Jan 20, 2017 at 16:20
Happens a lot while off-roading, especially older Vee-belt (rather than polyvee) belts.– John UJan 20, 2017 at 16:53
Took it into the mechanic and he saw the belt dangling underneath my car as I drove up. Restrung it and everything is good to go. Thanks! Jan 20, 2017 at 21:21
