My 2005 Mazda 3, 128,300 miles and manual transmission, has been running well for quite a while but a couple of weeks ago it started idling rough/low once warmed up and even stalled a few times when I was stopped at a light. It would drop below about 650-700rpms and either stall completely or almost stall, and then bounce back up, only to drop again. Since then, I've:
- Cleaned the throttle body by disconnecting the throttle body from the engine side and wiping the carbon off with a shop rag wetted with CRC TB cleaner. No noticeable difference.
- Cleaned the MAF with CRC MAF cleaner, then at the same time:
- Cleaned the throttle body again by going at it from the intake side as my brother held the gas pedal down to keep it open (electronic TB). After this and the MAF, the car idles low and rough, around 650rpms, but is no longer trying to stall.
- Cleaned the throttle body again in the hopes that maybe I missed some carbon and that was still causing the problem. This time I lightly sprayed some TB cleaner down and wiped it dry with a shop rag.
After cleaning the throttle body again my car started up a little rough (I assume because some TB cleaner was still in the system) and threw a CEL. Now the idle is somewhat better, around 675-750rpms I'd say, but still rough and, I think, too low. I drove it to AutoZone to get the CEL code and it came back with:
- P2195: HO2S (Front, RH) Signal Stuck Lean
- P2195: HO2S (Front, RH) Signal Stuck Lean (yes, the same code listed a second time)
- P0134: HO2S-11 (Bank 1 Sensor 1) Circuit No Activity Detected
AutoZone's recommendation is to replace the PCV valve. I had them clear the CEL but when I started the car up to drive home the CEL came on again.
Since I now have error codes I can do some more research into what other Mazda 3 drivers have experienced and what their solutions were but I'm wondering if anyone here has ever had a problem like this before. Thanks!
Edit: some non-mechanical things I'm considering doing just to see if they help.
- Running Techron through when I fill up next
- Switching from Shell gas to another brand, like Exxon or even the Quik-Mart down the street
- Filling up with a higher octane
