So i have a 1999 mitsubishi eclipse 2.0L manual transmission and it's not turning over at all. It just clicks. I changed the starter nothing and its still clicks the battery is good the altinater good as well. Can someone please help im completely lost.
Your earth connections are bad, undo all the earth straps and sand the connections with fine emery paper, re connect and all should be good
