I've got an '02 Jetta TDI (diesel) with ongoing problems (DTCs and low fuel economy) that seem related to the engine electrical system. The codes are all intermittent shorts to ground on various controls – the fuel shutoff solenoid, EGR control, and boost (turbo vane) control.
I'm starting to think that the problems might be in the wiring harness and I'm wondering what my options might be. For example:
  • Are harnesses available from the dealer or in the aftermarket?
  • Are harness parts available - especially the connectors and terminators?
  • Are used harnesses viable options?
I wouldn't mind building my own if the components are available. Would be happy to hear about others experiences and suggestions for how to go about this.
| improve this question | | | | |
  • any codes/problems with the maf or the cold start injector? – Ben Jan 14 '17 at 17:42
  • @Ben - We haven't had any MAF codes recently but did have EGR codes that made us question and replace the MAF sensor. I don't the the Mk4 has a cold start injector. – dlu Jan 14 '17 at 21:12
    If you don't have the cold start injector this diagram may be wrong but maybe backtrace the harness from the maf sensor it looks like there is a couple splices that power a bunch of related items. – Ben Jan 15 '17 at 0:47
  • @Ben, was there supposed to be a link to a diagram? – dlu Jan 15 '17 at 1:27
    try this link dl.dropboxusercontent.com/u/55044707/1.9%20early-late.pdf – Ben Jan 15 '17 at 1:38
